Ir para o conteúdo principal
Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
Pss5 not recognizing discs
Every time I turn on my PS5, the disc drive runs but says it does not recognize the disc. I have already tried replacing the disc driver laser, KEM-497aaa. The model is CFI-1115a.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Usually it is the laser, but it could be way more (drive board, other components on there, etc.).
I recommend to try with a new drive, and see what happens.
Note: Always transfer your original board (from the OLD drive to the >>> New drive)!!!
Can you let us know how that goes?
Thanks!
Esta resposta foi útil?
Pontuação 1
5 comentários:
I have already tried replacing the part 3 times that’s why I’m looking for any other ideas to try and help
por
Hi! Did you replaced the whole drive 3 times? Or just the laser? Thank you!
por
@dan0 I replace the whole drive!
por
okay, then I'm afraid it's related to either the motherboard or the PCB. Is there a way for you to test them (and do you have soldering experience)? If the PCB is broken, it would be difficult to fix as you cannot marry a new PCB to the motherboard. Otherwise I recommend to check with a local repair shop. Sorry.
por
Well, you can't re-pair the boards unless you happen to be Sony and have all of their proprietary pairing software. You might also try moving the component that actually pairs the drive PCB to the motherboard, but last I checked, that's not easy to do and requires microsoldering to pull off (But hey, try it if you want!). You could also try to figure out if there's a specific component on the board that's being problematic and replace it.
por
Adicionar a sua resposta
MoJama será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 86
