Ir para o conteúdo principal
Touchpad isn't working.
My Touchpad is not working and the cursor is not showing on the screen. I've tried to check i it is enabled on the settings using (fn + m) but it was already enabled.
What could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Well there an be multiple reason for this issue so i will suggest you to checkout the following guide it might help you in fixing the issue: https://www.systweak.com/blogs/how-to-fi...
Esta resposta foi útil?
Pontuação 1
1 comentário:
When I first encountered this problem, I fixed it by holding the power button for 15sec and my pc would restart itself and the touchpad would be working again.
Now it's no longer working when I try it.
por
Adicionar a sua resposta
Aphelele Shange será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 77
