Ir para o conteúdo principal
Other miscellaneous headphones and their repair pages.
Not able to hear anything
I use my Zebronics headset with my laptop. But for the past few weeks, I'm not able to hear anything when I connect it to the computer.
Update (01/16/26)
there's no model number written on it
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Reena, Zebronics makes a lot of headsets; what model is yours?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
As nearly as i can tell, it looks like yours are the Zebronics Zeb-Thunder model. According to the User Manual, it supports an 3.5mm Aux input jack and a micro-SD card.
In order to pin down where the problem lies, can you try using an aux input cord to connect to an audio source and see if you get any sound then? That will tell us whether it's solely a BlueTooth issue or if it's an audio problem. If you have a mSD card with some music tracks on it, you could try inserting that and see if you can hear music; that would help too.
Have. you tried pairing it to a different device, perhaps your phone, and see if that gives you any audio output?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
reena deepak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 57
