Ir para o conteúdo principal
Este Power Mac G4 possui portas de unidade espelhadas (Mirrored Drive Doors).
Can't install any programs
Hello I have a Power Mac g4 with 500 MHz CPU, 2 GB of Ram, one Maxtor 120 GB and the original 80 GB HDD. My problem is all .dmg image i download when finish and the system mount a error appear (corrupted or damage image) I google all king of solution but I can't fix it the Os i have are Panther and Tiger. I try with Lion, Cheetah, Lion and other X Os but i have the same error. Please help..
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you may have a corrupted system. Your machine will take up to system 10.5.8. Boot from the system installation disk, go to the second screen pull down menu to Disk Utilities. Select your boot drive in the left hand column and see if you can repair the disk. Next repair the permissions. That failing, copy your documents to the other hard drive then reformat the hard drive using the "write zeros" option and reinstall your system.
Esta resposta foi útil?
Pontuação 3
1 comentário:
oK i gonna do that and let you know...
por Compartilhar
Adicionar a sua resposta
Rongie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 938
