Ir para o conteúdo principal
O Lenovo ThinkPad E15 Gen 2 foi lançado em 2020. Ele pode vir com um processador Intel Core i3/i5/i7 de 11ª geração ou uma CPU AMD Ryzen série 4000.
Charging port doesn't work.
Charging port doesn't work anymore with any charger, if I put it in a certain position it works, but rarely.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
When a charging port only works at a specific angle—or intermittently—the issue is usually mechanical or contact-related, rather than a problem with the charger itself.
Common causes include:
Debris or Lint Inside the Port - Pocket lint, dust, or corrosion can accumulate inside the charging port and prevent proper contact. This is the most frequent cause.
Worn or Bent Connector Pins - Repeated cable insertion can loosen or deform the internal pins, leading to unstable charging unless pressure is applied.
Loose Charging Port Assembly - The charging port may be partially detached from the logic board or flex cable, especially after drops or liquid exposure.
Recommended steps:
  • Power off the device and carefully clean the port using compressed air or a non-metallic tool (such as a wooden or plastic pick).
  • Inspect the port with a flashlight for visible damage or corrosion.
If cleaning does not resolve the issue, the charging port assembly likely needs replacement.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Adrian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 78
Ao todo: 487
