Compressor doesn't start?
Give the replacement motor part number which isn't listed. But the motor is shown. Thanks 👍 😊
Esta é uma boa pergunta?
On the diagram this
would be a pressure switch. That would be the second thing to check after the on/off switch. You should be able to see resistance on the 2 terminals of the power plug with the on/off switch on. If not, short out the pressure switch and see if resistance shows - it should be relatively low, 1-5Ω.
If there is no reading then you might have a bad motor. Try reading directly on the motor leads.
BAsically.
Troubleshooting the Motor:
If the motor doesn't start, common checks include:
Esta resposta foi útil?
Could also be a bad capacitor....
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 370
