Ir para o conteúdo principal
fans on nothing on screen no beep
when i power my iBook the two fans are on , led on front is on , but no beep , nothing on screen.
the mac will heat normally as it is working, it seems it is always in sleep mode.
i removed the battery and power up with ac adapter but same problem.
Help
Rana
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
First let's clear the PMU 1. Step 1 Quit all of your active applications and shut down your Mac. 2. Step 2 Once your computer is completely shut down, disconnect the computer's AC power Adapter and remove the battery from your Mac. 3. Step 3 Press and hold down the power button on your MacBook or MacBook Pro for at least five seconds and then release the power button. 4. Step 4 With your Mac still shut off, reinstall the battery in your MacBook or MacBook Pro and reconnect the AC Adapter. The PMU/SMU has now been reset on your computer. Does it start up?
Next we'll zap the PRAM. Hit the start button, hold down the option & command --P & R keys wait till it tones three times then try to start up. Please let us know the results so we can proceed. Thanks
Esta resposta foi útil?
Pontuação 2
2 comentários:
Good answer +
por
i have the same issue and these steps did nothing for me. I'm thinking its a logic board videoc ard issue.
por
Adicionar a sua resposta
haddad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,534
