Ir para o conteúdo principal
does it matter about the model number on the heat sync
do the heat sync have to match the original or current heat sync model number or can any replacement heat sync work with the current xbox one as i think it is the heat sync that is the issue not the cooling fan and if i get the wrong or incorrect heat sync model number it may not work correctly
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Matt!
No, the heat sinks are basically the same. Just make sure you get the Xbox One (1st, original) model heat sink.
Guide: Xbox One Heat Sink Replacement - iFixit Repair Guide
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
was not sure if they had to match but better to have another opinion than to get it wrong
por
No problem at all! They should match as long as you got the Xbox One (original, 1st) model.
por
Adicionar a sua resposta
Matt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 14
