Ir para o conteúdo principal
The Makita SP6000K1 is a 6-1/2" circular saw with a 55" guide rail system, featuring a 12.0 AMP motor and variable speed control for versatile cutting in various materials, with a maximum cutting capacity of 2-3/16" at 90° and 1-9/16" at 45°, and bevel capability from -1° to 48°.
Why the saw can run but there is no cutting strength
The saw can run but when cutting something it has not powerful enough, no cutting strengths.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This is what AI has to say using a simple search: A 12A AC motor lacking power can be caused by electrical issues like low voltage, open windings, or a bad capacitor, as well as mechanical problems such as worn bearings, overload, or a lack of lubrication. To diagnose the issue, check the power supply, test the windings and capacitor, and inspect the bearings for proper lubrication and free movement. I would start with a capacitor if it has one.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Xiongwei Rong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 15
