Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
LCD problem it seems to be a cable issue
Hello, I have a problem with my 2016 13" A1706 MacBook Pro LCD.
When it is cold, there are black and dark lines on the screen. This can be fixed by pressing the top of the LCD or heating the back of the LCD. It is just like this at different angles and it does not change. The screen does not turn off or on. It has very little bounce. Either the screen has little color. The color is fixed by pressing. Or the screen is completely black at first.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sadly, this series had a lot of flex cable issues. The most common is the stage light effect as some of the backlight LEDs wouldn't lite as there string trace would get damaged.
The other issue was the chin area just under the display area would get pressed in by an object crushed between the upper case and the display severing the displays driver lines flex from the T-CON board within the uppercase.
And another fault is similar to the damaged chin plate cutting into the ribbon cables, here the metal oxide traces within the LCD it's self get damaged as the chemical processing makes the LCDs glass base brittle where the traces sit so the face of the display looks fine but micro fractures in the base or even a hard break can cause stripes as well as incomplete images.
This will likely require a new display assembly MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here's the guide to put it in MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
Imagem de Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.
Produto
$444.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
omidreza kh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 34
Ao todo: 34
