Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 11. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 11.
How to hard reset iPhone 11
how to hard reset iphone 11
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
how to flash iphone 11
por
Adicionar um comentário
1 resposta
Hello.This operation will not erase the data.
The procedure is as follows.
Press the volume up button and release it immediately.
Press the volume down button and release it immediately.
Press and hold the side button (power button).
When the Apple logo (apple mark) appears, release your finger.
Matters to be attended to
This procedure is intended to troubleshoot if a normal restart is not possible or if the screen freezes.
If "hard reset" means "initialization" to return the iPhone to its factory state, the operation method is different. After initialization, all content and settings in the iPhone will be erased. If you want to initialize, you need to do it from the "Settings" app or connect it to your computer (Finder or iTunes).
This is the end. From gkps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Light up the flashlight from the control center
Open Control Center: For iPhone 11, tap the upper right corner of the screen and swipe down.
Tap the flashlight icon: Tap the flashlight icon to turn on the light.
Turn off the light: Tap the icon again to turn off the light.
"Turn on" the flash with the camera app
Launch the camera app: Open the "Camera" app from the home screen.
Tap the flash setting icon: Tap the lightning mark displayed at the top left of the screen.
Select "On": Select "On" from "Auto", "On" and "Off".
Setting to light up the flash when receiving incoming calls or notifications
Open Settings: Open Settings and select Accessibility.
Tap "Audio and Visual": Select the "Audio and Visual" item.
Turn on "LED Flash Notification": Turn on "LED Flash Notification".
Set to muting: Turn on/off "Flashing at muting" if necessary.
From gkps.
por
Adicionar a sua resposta
Oguta Sokya será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 101
Ao todo: 585
