Ir para o conteúdo principal
Repair and disassembly information for Logitech's ergonomic MX Vertical wireless mouse. Released in 2018 and identified by model number M-R0074.
Is it possible to replace MX Vertical rubber pads?
I have been using the MX Vertical for over 5 years now. For some time, the rubber pads around the mouse has become sticky and worn out. I tried to clean it following the procedures from Logitech website, but it is not really effective. As everything else in the mouse is good, I would like to replace the parts with a new rubber pad, but cannot find any sort of guide for it. Does anyone have a similar issue? What have you done to overcome it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
THAT "rubber" is sprayed on - don't think it is even rubber. Once it becomes sticky it doesn't clean. I have removed that stuff from other things using 90%+ ISO. The plastic below it isn't sticky.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Hermann Simon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 49
Ao todo: 63
