Ir para o conteúdo principal
Apple's smallest iPhone 14 was released on September 9th and comes with a 6.1" OLED display, an advanced dual 12 MP camera system, and a front camera with autofocus. Successor to the iPhone 13.
iPhone not responding to touch after drop. What needs replacing?
I dropped my iPhone 2 days ago, and the back completely shattered. I know that it will for sure need to be replaced. However, now my display isn't responding to touch at all, and I have 2 green lines and a purple line on my display (front is not cracked at all). I did a hard reset and it rebooted but still no luck. What needs to be done?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Looks like both sides got damaged!
The screen is by far the more important side to fix as you can cover the back glass with tape to prevent the shards from slipping out and cutting you and then maybe a case as well.
Here's the needed part iPhone 14 Screen and here's the guide iPhone 14 Screen Replacement that will fix the color bars (damaged LCD) and touch (sensor) aspects of the screen.
Imagem de Replace a scratched or cracked front panel glass digitizer screen or a malfunctioning display with an aftermarket LCD.
Produto
iPhone 14 Screen
$99.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Maritza Cruz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 39
