Ir para o conteúdo principal
Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
My laptop doesn't display on screen
My laptop doesn't display.. Hp G250
But it switches on properly problem is that it doesn't display on the screen not even with HDMI cable.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Idk if this will work, but you can try.
  1. Power off completely.
  2. Unplug the charger.
  3. Remove the battery.
  4. Open the back panel and locate the RAM sticks.
  5. Remove them carefully.
  6. Clean the contacts gently (use a dry cloth or compressed air).
  7. Reinsert them firmly — or try one stick at a time if there are two.
  8. Power on again.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Cheki mavado será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 31
