Why are my skates turning the opposite way
My skates are turning the opposite way(turning right when I put pressure to the left and vise versa)
Esta é uma boa pergunta?
Hello @leoemerald
Thanks for posting the picture! Before I even saw it I thought I knew what might be the problem and the photo confirmed it.
The trucks are mounted backwards. In other words, the rubbery cushion on the truck must face inward. You currently have both facing outward.
Both trucks at the moment need to rotate 180 degrees. You do not need to swap places, just unscrew one, turn it 180 degrees and then mount it again using the same 4 screws and holes. Then do the same with the second one.
All the best to you!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 33
