Ir para o conteúdo principal
Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
Display issues and error code 255-1
Playing PS5 games on a PS5 Digital causes screen flickering and error code 255-1, but playing the PS3 port of God of War 3 on a PS5 does not. What's going on?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Do you mean error code: CE-108255-1?
This one is related the game or app crashed due corrupted data.
Which games are having issues?? Or all of them? I would reinstall the game and see if that works. If not? Then I would format the console (make sure you make a back up first!!!), and reinstall the software.
If that fails as well with all the games, it's probably SSD related... You can try to put in a M.2. SSD install the game there and try it again.
If that also fails, you might want to take a look at the SSD. The only issue is, that it's soldered on the motherboard, so some serious soldering skills and equipment are required to replace it.
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yes, playing native games causes screen flickering and error code 255-1, and it happens with games like Sheep Hoof Mountain Soul and Cosmic Robot. I've tried everything mentioned above without adding a hard drive. Anyway, playing backward-compatible games is fine, but playing native games causes screen flickering and error codes. I asked surrounding experts and they all say the APU is not suitable. ...
por
It could be APU related. I would try to get a M.2. SSD (as a external USB drive won't work) and try the games from there. Still having issues? It could be APU related then.
por
Adicionar a sua resposta
黄家乐 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 40
