Ir para o conteúdo principal
The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
All LEDs not working anymore (everything else is OK!)
ALL of the LEDs (on/off, Bluetooth) are not working anymore - anything else (bluetooth, audio menu, music, buttons) is working.
Any idea, what to check if just the LEDs are the problem? Any loosen connector?
It happens just between two days of normal usage :-/
Making a "factory reset" did not solve the problem.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
After connecting the box to USB power supply the LEDs get instantly back to work - strange :-/
So far problem is solved - if I do not report back here again.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 30
