Ir para o conteúdo principal
Officially licensed Joy-Con alternative for the Nintendo Switch. Released in September, 2019, identified by model numbers NSW-182 and NSW-182U.
Replacing the analog stick caps.
My analog sticks are really beat up and need to be replaced. I tried googling what kind of analog stick cap replacements would fit well in these controllers, but could not find an answer. Does anyone know which new sticks would be best to buy?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
These are really hard to find if you are able to find them at all...
I've read once that they tried Xbox caps, but not sure if it worked or not. These are the ones you can try...
Otherwise you might be able to find a broken Hori Split Pad Pro and use the caps from that one.
You can also ask Hori them selves, but I don't think they are able to help you further, but you can try at least!
Esta resposta foi útil?
Pontuação 2
2 comentários:
I might have an xbox controller sitting around somewhere. I'll try to swap them and test it out before ordering anything.
por
Alright! Please let us know how that goes! Thanks!
por
Adicionar a sua resposta
Zach B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 55
