Ir para o conteúdo principal
Released in April 2019, the Roborock S5 robotic vacuum cleaner is the base model of the Roborock S5 Max. Like most Roborock vacuums, it has LiDAR navigation and a high capacity dust bin.
Clif Sensors error because of dust
How i can remove the clif sensors to clean them from the inside they have dust inside which i cannot clean
i tried to open the vaccum but i cant find how i can remove them to clean them
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@antonismar70785 ,
A pretty good guide to disassemble and repair this puppy is HERE, it includes a complete tear-down, including the sensors you want to get at!
Likely you've already solved this yourself, but if not or for others needing the information... here you go...
Good Luck
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Antonis Mart (DarkLord_gr) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 42
