Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
Green Light Only - Battery not charging
Early 2011 MBP A1278 (820-2936) Getting only a green light on the charger.
OCLP 10.13.6 > 12.7.8 Monterey (OS running VERY smoothly)
I am 99% sure the DC In board is functioning OK (Tried another), no dirt, clean pins. SMC & PRAM Resets to no avail. Logic board is spotless, never water damaged, Charger is OK. I cannot see any blown components under the michaelscope. The battery is detected in Apples system profiler but it reports the battery is not charging. Coconut reports everything is fine & the battery IS charging! The battery charges OK in another same unit so 100% no battery issue. Any ideas on what I can try in case I missed something?
R7051?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Love that michaelscope! Aka microscope.
por
@danj oops, my spelling is sometimes a bit off... like yours ;) :P
por
Adicionar um comentário
3 respostas
Solução escolhida
Turned out to be a just a poor connection / solder on the R7051
Esta resposta foi útil?
Pontuação 1
The comparator logic likely messed up. There is two resistors the ISL chip measures to see the voltage applied and drawn. Luis Rossmann has a good vid on this you should check out. I'll need to dig for it when I get home.
Pontuação 0
3 comentários:
OK thanks, please add the link when you can :) R7051??
por
@danj Bright Green light to suggest fully charged but it isn't charging. I am taking it to the menders today to check this R7051? as it looks suspect. https://www.youtube.com/watch?v=FGYrykiL... (7 minutes so...)
por
If your Early 2011 MBP (A1278, 820-2936) shows only a green light and won’t charge, despite a good battery and DC-in board, check the charging circuit—especially the ISL6259 (charging IC) and related current-sense resistors (R7050, R7051). Verify PPBUS_G3H voltage (should be ~12.6V). If low, the ISL6259 or Q7055/Q7056 MOSFETs may be faulty. Inspect for corrosion or poor solder joints around the charger IC. Also, reseat the battery connector and inspect SMC signals (SMBUS_SMC_BSA_SCL/SDA). If all else checks out, replacing the ISL6259 or associated MOSFETs often resolves this issue.
Pontuação 0
1 comentário:
It was the R7051, we cleaned up that area before surgery and discovered it was wobbling (cracked solder joint) and a quick blast of the hot air fixed it very easy :)
por
Adicionar a sua resposta
livfe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 89
