Ir para o conteúdo principal
Calculadora científica da Casio com 252 funções e display de matriz de pontos completo. Também possui função de repetição e sete memórias variáveis.
The zero button of my calculator didn't work
When i click the zero button of my calculator it didn't appear in the screen. How should i repair it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If this calculator is very old and dirty, the contact points on the board might need cleaning. This may be hard to do depending on the calculator, but you will want to unscrew the back of the cover, and use a jimmy tool to pry into the case. Move the jimmy all around the edges of if until it pops off. Take out the board. There will be a very large ribbon cable like thing with a bunch of wires running through it. You are going to want to take high concentration isopropyl alcohol (I'd recommend 90%) and clean the large ribbon cable on the side that touches the buttons. Reverse the disassembly steps to put it back together and you should be done with the repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Reygem será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 205
