Ir para o conteúdo principal
Repair and disassembly information for Google's Pixel 8a Pro smartphone, released on May 14, 2024. Identifiable by model numbers GKV4X (5G Sub 6GHz) and G8HHN (5G mmWave + Sub 6GHz).
Is there any replacement for the flashlight module?
I have a broken flashlight, the part with the light on it snapped off from the cable.
I was looking for that part alone, but I don't see it, does it come in any group of parts?
If there's any way to get it, I was wondering if there is also a guide to replace it or if it's not possible.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
On gear tear, there is a replacement (I can't access the website at school, so I would check the compatibility). To install it there is a guide on the IFIXIT website to replace the 8a flash adhesive (you will want to get a new one of those too).
Esta resposta foi útil?
Pontuação 0
2 comentários:
Are you sure it's available? I've taken a look over there, but there's only modules for other Pixel models.
About the guide, the adhesive replacement doesn't cover the full module removal and installing a new one.
por
I am not completely sure. When I get home from school, I can check to website on a non-blocked computer. For the guide, the following link might be a help to you. For me its at least better than nothing. Google Pixel 8a Rear Cameras (Wide and Ultra-Wide) Replacement
por
Adicionar a sua resposta
Shy Frog será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 53
