Ir para o conteúdo principal
Remove Display Cable from the Logic Board
Dear All.
I do not figure out how I can remove the Display Cable from the Logic Board without distroying it.
Could someone describe exactly how to do it, it would be perfect if there would be some additional pictures to show how.
Best regards
MacWiniac
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Carefully read the guide all the way through before doing this: PowerBook G4 Aluminum 15" 1.5-1.67 GHz Display Data Cable Replacement
Esta resposta foi útil?
Pontuação 3
1 comentário:
Dear Mayer.
I have read all the guides carefully, but in step 15 it is only stated to disconnect the 13 cables, but not how specifically to disconnect the display cable from the Logic Board. However in step 14 there is specifically described how to disconnect this special connector. That is what I like to have for the display cable.
Best regards,
MacWiniac
por
Adicionar a sua resposta
MacWiniac será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 550
