Ir para o conteúdo principal
Originating from the Shark Rocket HV320 series vacuum cleaners, the Shark Rocket HV322 was released in 2014 and had features like a detachable dust bin, LED headlights, and specialized pet tools.
How to replace the small wheels on the bottom of vaccuum
The small wheels on the bottom place have worn off. How do I replace them
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Easy, peasy, Sandy & Anna. That little shaft it rides on is held by the plastic ridges on either side of it, and removal is no more complicated than sticking a flat blade screwdriver under the wheel and prying up on it. Replacement consists of snapping it back in place.
I know this because there are screws under the wheels on my Lift-Away so I have to take the wheels out to remove the bottom cover. Yours doesn't have those screws, so the guide doesn't show how to take the wheels off, but if you check out one of the Lift-Away guides like this one, Step 2 shows you what you need to know.
Shark Navigator Lift-Away Deluxe NV360 Roller Brush Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Sandy and Anna Miner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 38
Ao todo: 144
