Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
How to replace/fix home button?
After falling on the floor (1 meter high drop), my 8GB iPhone operates properly except for the home button which does not work anymore. I can "click" with it but it has no effect. The USB connector works well as i can recharge the iPhone without any problem.
i have not found any tutorial/guide for changing a broken home button, or any connector that may be connected to it.
On your photos, i have not seen the Home Button... :-(((
Any ideas, or should I try to sell it for parts?
many thanks for your feedback,
Best Regards
Jean-Baptiste
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
No need to get rid of the iPhone due to "Home" button malfunction. Search Google for "iPhone home button repair" you will find the part(s) you need. Make sure you get the correct button (2g, 3g, 3gs).
Update
No need to vote down. I didn't post links because I wasn't sure if it was allowed. You didn't say if you had a 3G or 3Gs, I will assume you have a 3G. Easiest way to change the home button and circuit is to get a complete top (digitizer, glass, home button, etc). Just use ifixit's tear down guide to disassemble and reassemble.
Here is a Ebay link to the unit: http://tinyurl.com/yzhnfe5
It may not be the cheapest solution ($67.99 USD), but it will be the easiest.
*Please vote up if I've helped
Esta resposta foi útil?
Pontuação 4
1 comentário:
That's not real helpful- can you link to a button and a guide?
por
Adicionar a sua resposta
JeanBaptiste será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 21,348
