Ir para o conteúdo principal
Lançado em 2009, o Dell OptiPlex 780 Small Form Factor é um mini computador desktop da linha OptiPlex 780 da Dell. Identificado pelo número de modelo DCCY1F.
My PC won't boot or take input
Hi.
So recently, let's say during the past month, my PC sometimes would just go dead. I generally hibernate it bc I don't want to wait for it to startup and have to reopen all my apps. But sometimes when I press the power button, it's completely dead. So I tried switching power cables which worked for a while, but soon even that didn't work. I ended up doing a clean reset on one of the few miracle moments it did start (Win11 Pro). And for a couple weeks it worked perfectly, until it didn't. It either went dead or booted onto a blue screen that said diagnose device (paraphrasing here, you get it). Now, everytime I start it, it beeps once and opens onto a text screen saying 'date and time inaccurate'. There are options to boot or go to startup settings and what, but it's not accepting any input from my keyboard. Please help me someone.
Thank you in advance, and sorry for the essay but I felt I needed to be detailed.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
There is a CR2032 battery that needs replacement inside the computer. Easy to access.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @faiyazdadamia
based on my experience, i believed the power supply is having some issues, which is probably caused by bad capacitors
https://crawlsbackward.blogspot.com/2016...
another thought on wrong timing and lost of setting in bios is to replace the cr2032 button battery.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you so much. I do have a another case with a PSU but do you think it would be possible to switch the motherboard? I know that the motherboard is built per case but I have projects on my PC that I need to work on
por
@faiyazdadamia, well you can try, and most impt..... backup important data
por
Adicionar a sua resposta
Faiyaz Dadamia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 401
