Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
bottom lcd purple in some spots replacement didnt fix
so i had dust under my digitizer which was causing the digitizer to not work so i cleaned it with 70% isopropyl alcohol which im sure isnt a high enough percent but i didnt think of it much and i dont think i waited long enough for it to evaporate because when i turned it back on it started bugging out moving on its own and stuff so i disconnected the battery to wait till the morning and then i put the battery back in and the bottom screen is purple and the digitizer stopped working so i just went to aliexpress because im broke and i bought a replacement screen along with a digitizer and they seemed nice quality better than oem so i put everything together made sure all ribbon cables were seated correctly and i turned it on to see if it worked my digitizer worked but my screen is still displaying multiple colors as purple i dont have any pictures of it but when im at the home screen the border around the apps are almost entirely purple and some of the background
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
So you replaced the screen already and it’s doing the exact same thing as the original did?
I hate to say this, but then it’s most likely motherboard related… is everything okay on there? Please clean everything with isopropyl alcohol (98-99%). If possible, please sent some photos. Otherwise a morherboard replacement is required.
Please let us know how it goes and if you need guides!
Esta resposta foi útil?
Pontuação 0
4 comentários:
okay sorry for the late respose but i did clean everything that had to do with the screen and i also made sure that all the connectors were seated properly although that didnt seem to fix the issue
por
Could be CPU/GPU related... I know that sometimes the Nintendo DS lite could have experience the same issue. In the worst case, a motherboard replacement is required... Sorry.
por
yeah its alright its only cosmetic which im thankful for so ill probably just use it until i buy a n3ds but thank you for your help man i appreciate it much love brother
por
Always happy to help :)!! If you have any other question, please let me know! Wish you the best!
por
Adicionar a sua resposta
swaggyp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 64
