Fan not spinning, SSD replaced
Long Story:
My girlfriends iMac has been going extremely slow so thought I would attempt to upgrade it since it had a fusion drive. I bought a new SSD (1TB OWC Aura Pro X2 PCIe) and 64 GB ram (OWC 2666Mhz). The install went well and before reattaching screen I thought we would test it out, booted up fine, and installed mac sequoia on the new SSD.
Was reasonably fast for first 5-6 minutes, but then started to get real slow. Clicking on anything on system settings would take 30-40 seconds before switching menus.
Shorter Story:
(Replaced SSD and Ram)
Upon pulling screen back with Mac still on, I noticed an extreme amount of heat coming out and the main fan in center was not spinning. Did some googling and downloaded macs fan control, put it on full blast, still nothing, shows 0 rpm in MFC.
I went ahead and ordered a new fan and pulled the existing fan out. With the existing fan I cut off the connector and put 12V between Pin 1 and 2 from the left and fan would jump, stop, then spin full blast so it seems like the fan itself was probably good.
Any ideas of what issue could be once I get the new fan in? Everything else I've read says the logic board itself, but if there are other ideas I'd love to hear them.
Esta é uma boa pergunta?
1 comentário
UPDATE: Even though fan would spin with 12v from an external power supply, it still turned out being the fan bad. New fan went in and started spinning immediately on power up.
por Shane Anderson
