Ir para o conteúdo principal
Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Will MacBook Pro turn on if I removed the Battery
2 weeks ago Instead of leaving my MacBook in sleep mode like I normally do with the charger connected, I did a complete shutdown afterwards removing the charger and cable to charge my phone. The following morning I tried to power the laptop up and it was completely dead nothing at all, no sound, no shift key light, no dead battery charge screen.
I tried all the key functions Apple suggests to get it up and running but still nothing. There has never been any water damage to it or anything.
Battery replacement is recommended when I would click on the percentage but it’s never been a big deal because I was able to to still get a good 3 or more hours of run time on it as long as I did not have videos constantly playing. Yes, sometimes the fans would speed up and get real loud like a tiny turbine engine depending on what website I was surfing getting very warm to the left hand side of the track pad but once you click out of the site the fans would slow down.
I use the laptop every day for 6 years with no problems and it just seems so stupid to me that it would die out of nowhere after a shutdown to prevent something like this to happen.
Apparently 2018 models are considered vintage laptops to Apple therefore parts are difficult to come by meaning that no matter what, I will be told the main board is fried therefore, I must purchase a new laptop and that’s something I can’t afford to do right now.
So here’s my question that I hope someone can answer for me, if I purchase a P5 screwdriver and a T5 screwdriver, open up my laptop and clean out whatever 6 year old dust there is inside and carefully disconnect the battery by following iFixit instructions, reconnect the USB-C charger to one of the 4 USB-C ports and try to fire it up would it turn on if there was nothing wrong with the logic board and stay on to get my data off off of it?
I don’t want to spend money on replacing a battery only to find out that it’s not going to turn on. I’ve look all over the internet for something on running a MacBook 2018 and up without a battery and I can’t find anything at all so whoever definitely knows the answer please let me know
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sadly the recover option Apple put in within the older 2016/17 models was removed. And without a charged battery there is no means to even tell if the problem is the battery or the logic board.
Some people have converted an old dead into a pseudo battery emulating via a bench power supply what a real battery would supply to the logic board including the needed BMC sensors. Clearly that's not an option here. You might find an independent repair shop who has the needed battery to even prove or disprove if that's all that's needed. But the service battery warning tells us the batteries days are numbered and they do fail hard like what you encountered here.
I'm betting you only need a battery, and if the logic board is the issue then you'll need to find someone with the needed board repair skills as you can't access the data on your system without the logic board working.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Henry Kerr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 245
