Ir para o conteúdo principal
Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
Apple Watch 44mm SE GPS only screen adhesive
Is the Apple Watch 44mm SE GPS only screen adhesive available? I would like to replace my battery using the guide by D Schnabelrauch which at reassembly just mentions "remove leftover adhesive...install new adhesive". The parts list does not mention screen adhesive. Is this adhesive available from iFixit if not is there a suitable workaround?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
There are loads on ebay
por
Adicionar um comentário
1 resposta
Solução escolhida
@nigelmann99450 The Tesa tape that iFixit offers is a generic adhesive tape you can use to cut to shape for the Apple Watch SE
If you want something specific, you'll have to do some digging, as you can find pre-sized adhesive for your watch. For instance, this site has 42 & 44 mm options for the SE: https://www.repairsuniverse.com/products...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nigel Mann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 228
