Ir para o conteúdo principal
solenloid decompression problem. Solved!
Road Star XV 1700 2006, solenloid pushes the two rods in, but valve does not stay open to decompress. Anyone an idea ? Cheers. Two days later : After opening up the crank-carterI, I found one of the two rod- levers was slightly bent, so it didn't push in the decompression-rod enough to engage the extra crank-opening-moment of the exhaust-valve.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
So if changing the starter-motor, start-relay and decompression-solenoid don't resolve the problem, take out the engine oil, then take of the crank-carter and check if the two rod-levers push both rods in ( equally ).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
kees van schaik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 24
Ao todo: 244
