Ir para o conteúdo principal
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
Why doesn't the computer turn on?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @zioneaso
What is the make and model number of the motherboard?
Are there any lights showing on the motherboard (or PC case when you try turning on the PC?
por
Adicionar um comentário
2 respostas
Do you have a PC repair shop nearby? Maybe it's best to take it to them. With so little to work from it's anyone's guess what the problem it here.
Esta resposta foi útil?
Pontuação 0
It could be a number of things. First, check if the power cable is securely connected and if the outlet works. Try a different power cable or outlet just to be sure.
If the fans don't spin or there are no lights, it might be a power supply issue. If the fans run fast but there's no display, it could be a hardware failure like RAM or motherboard. Also, look for any beeping sounds—they can indicate specific problems.
Pontuação 0
Adicionar a sua resposta
Zion Easo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 69
