Why is my PowerBook g4 screen white?
I have a powerpook g4 with a broken screen. I replaced it, but I have a white screen (no display). I plugged in an external screen and it came great.
Esta é uma boa pergunta?
I change video cable also but still white screen
Esta resposta foi útil?
If your machine works as it should on an external monitor then the video problem on the internal monitor should be related to the LCD panel or the LVDS cable.
Here's a link with great pictures of someone who had the same broken screen problem you have. http://www.david-reitter.com/software/Po...
The first thing to do would be to reseat your cables and review carefully the installation instructions you can find here: PowerBook G4 Aluminum 15" 1.5-1.67 GHz Display Replacement
Are you sure thenew display was good? Where did it come from?
thank u. i bought it from laptop aid on ebay
looks like some very low prices. Problem s that we don't know if it works
Looks like a LVDS (video) cable issue. Double check the connections to the main board and to the LCD panel.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 4,412
