Ir para o conteúdo principal
The Golf Mk5 was introduced in Europe in the autumn of 2003, reaching the UK market in early 2004. In North America, Volkswagen brought back the Rabbit nameplate when it introduced the vehicle in 2006.
Why is my car idling not consistent
Car does not idle consistently, also cuts power when driving at low speed
Esta é uma boa pergunta?
Pontuação 1
1 comentário
My experience is similar, when the engine is started, it doesn't sound stable and steaming seems low whereby even in motion sometimes cuts engine power.
Could the problem be electrical thereby needing the vehicles updated software to run a reset?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@ikennanwosu While it could be an electrical problem, software updates are unlikely to help; besides that's normally something that can only be done by a Volkswagen dealership.
Have you had your car scanned for trouble codes? The engine computer generally records issues like that with codes that can help identify the problem. Scanners can be purchased inexpensively online; these plug into the car's OBD-II port and connect via Bluetooth to an app on your phone. There are plenty of free ones available; I personally use one called Torque.
Is the Check Engine light on? Please check to see if your car is showing any trouble codes then come back here and tell us what you found. If it doesn't have any codes, let us know, otherwise tell us exactly what code(s) your car is giving you.
We would also need to know what year your Golf is, assuming you have the same car as the original question.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Keith Cebo Matshoba será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 45
