Ir para o conteúdo principal
How to clean speaker
Esta é uma boa pergunta?
Pontuação 12
Adicionar um comentário
8 respostas
Pergunta mais útil
This generally works if the speaker sound is very low but you can hear it. If you can't hear anything then you might need a speaker replacement but it wouldn't hurt to check to see if its cleaned.
The way I clean phone speakers is with a toothbrush, isopropyl 99% alcohol and compressed air.
  1. Look at speaker to see if you can see anything blocking it
  2. Take dry toothbrush and brush the speakers using a little pressure but not much (you may see stuff come out keep going for like a minute)
  3. Puff the speaker area lightly with some compressed air
  4. Test call to see if sound improved
  5. If not, Put a couple drops of isopropyl alcohol on to toothbrush and complete step 2 and 3 again.
  6. Test call to see if sound improved
  7. If not, put could of drops of isopropyl alcohol into speaker area and plus a medium stream of air into speaker area not to powerful, then follow up with one minute of brushing.
  8. Test call to see id sound has improved
  9. If following this doesn'twork then more than likely you need a speaker replacement.
Esta resposta foi útil?
Pontuação 1
Spker cleen this
Pontuação 1
Ho my best wishes
Pontuação 1
In my realme phone mic can't work properly when I was calling with another one voice can't hear and not going to another person
Pontuação 1
1 comentário:
لا يعمل الميكرفون بشكل صحيح ولا استطيع سماع الطرف الاخر
por Compartilhar
Its not working proper sound of my phone
Pontuação 0
How to clean the speaker
Pontuação 0
Realme narzo 60 display repair
Pontuação 0
How I can clean my phone speaker
Pontuação 0
Adicionar a sua resposta
Girraj Goyal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 33
Últimos 30 dias: 104
Ao todo: 5,663
