Ir para o conteúdo principal
The DualShock 2 Analog Controller first appeared with the PlayStation 2 and featured only minor cosmetic changes in screw locations etc.
left analog stick is becoming increasingly squeaky
Hello,
My Dual Shock 2 is still working well after all these years! However, the left analog stick is becoming increasingly squeaky, and has begun to stick on rare occasion, but still functions near perfectly 99.9% of the time. Is there a simple trick to loosen the stick, and perhaps any buttons such as square and X, to prevent squeaking and sticking, using a household lubricant product such as WD 40?
Thank you,
Daniel McNamara
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Daniel!
First I would try to clean everything in there.
You can just use a wet cloth and clean it (make sure that the cloth is not too wet!).
For the stick, you could use ispropryl alcohol and clean it and see if that makes a difference!
If not, then you might want to replace the stick (worst case).
Please let us know how it goes and good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
D_mac08 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 34
Últimos 30 dias: 125
Ao todo: 554
