Ir para o conteúdo principal
Lançado em 3 de dezembro de 1994 no Japão e em 9 de setembro de 1995 na América do Norte. Modelos SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x e SCPH-900x.
My laser doesn't work
I tried to understand what is the problem, and maybe i have the solution too, but firstly I want to be sure of what I'm fixing, before I take another laser that costs money ☺️. The CD doesn't spin, but it seems that this is due to a lack of power coming from the mother board. On the cable that comnects the mother board to the optic group there is a little black dot. Chatgpt says that it is a burn caused by some sort of electricity malfunctions.
Can anyone help me?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Hi!
It's hard to say without photo's. Can you share them with us?
Anyway, it's possible that some capacitors failed on the motherboard and prevent the Playstation it's drive from working.
Also, the laser could have failed.
But before we can tell, we really do need pictures.
Thanks!
Esta resposta foi útil?
Pontuação 2
Hi there!
thank you for your answer, really appreciate it. This is the photo of the black dot on the cable. Tell me if you need more, thanks for your help!
Imagem
Pontuação 0
1 comentário:
My pleasure! Thanks for the photo! This is not a burn mark. This is straight from the factory. Some ribbons do have marks (rare, but it’s there). Most likely thing is that your laser just died or starting to die. I would replace the laser deck as complete. A new laser deck comes with everything, including a new ribbon cable. The cable is fused, so it cannot be replaced (everything is replaceable, but it will be VERY difficult). The only thing you need to transfer is the power cable, and that’s it.
por Compartilhar
Here there are some photos of the motherboard, if you see any problem let me know. Thanks for your answer by the way, I just want to be sure making you see these pictures, even if I think it seems ok. Thank you very much!
Imagem
Imagem
Imagem
Imagem
Imagem
Pontuação 0
1 comentário:
Hi again!
The motherboard looks fine, but it is modded. Be aware that a broken modchip can cause issues with reading games. So it’s either your laserdeck or the mod chip.
por Compartilhar
Adicionar a sua resposta
Francesco Avantario será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 267
