Ir para o conteúdo principal
A HD pocket camcorder to compete with Flip mino/ultraHD. Many view the Kodak Zi8 as having a better set and a camera worth considering more then the Flip.
Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
por
Adicionar um comentário
1 resposta
Solução escolhida
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
Esta resposta foi útil?
Pontuação 0
2 comentários:
por
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
por
Adicionar a sua resposta
jmartz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 90
