Ir para o conteúdo principal
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
TI 84 Plus CE is stuck in the validating loop
Hello,
I am trying to fix the calculator. When plugged in it is stuck in the validating loop. I have attempted to remove the battery, download the TI software, but when I plug it in it through the USB it does not recognize the calculator. There is mention of a button battery that can be replaced but I cannot find that either. Should I purchase a whole new battery? Is that maybe why it will not get out of the validation loop or be recognized?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This has been a common issue. You need a new battery. If your calculator is less than 2 years old then contact TI Cares and they will send you a new battery for free. https://epsstore.ti.com/OA_HTML/ibeCZzpH...
The TI-84 Plus CE only has one battery. The TI-84 Plus has AAA batteries and a coin cell battery.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Molly Rhodes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 97
Ao todo: 508
