Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
turn on and then immediately off
My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
Esta é uma boa pergunta?
Pontuação 24
6 comentários
trun on problams
por
plz talk to me
por
Ha (that happiness to me to)I don't know how to fix it
por
How to fix a DS lite that turns on and instantly off
por
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
por
Exibir mais 1 comentário
Adicionar um comentário
8 respostas
Pergunta mais útil
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
Nintendo DS Lite
Though there is another apparent option which centers around possible hinge damage. Does it appear that there was any damage to the hinge in the fall?
If so you may just need to replace the casing and one of the screens to rectify the issue. In which case the above guides would also be useful.
Also, if it turns out you need replacement parts, this is a good spot to start looking.
Esta resposta foi útil?
Pontuação 13
6 comentários:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
por
That´s the answer I was looking for. tnks
por
it work on my ds
por
turn on problams
por
Lol, it's been a long time since literally "jiggling the cables" was a solution. Disconnect, and reconnect, the 3 ribbon cables, works like a charm.
por
one of the connectors is not connected anymore
Pontuação 1
hold the power switch on a maximum 1 hour and keep the ds game inserted.
if your daughter wants swap the ds game your daughter will need a gba game
Pontuação 0
maybe it was just from the fall
Pontuação 0
Hi, if you’ve got no flash screen, consider to try my fix here.
The DS won't turn on. Green light flashes for a second.
Pontuação 0
The problem might be in the battery compartment
Pontuação 0
i will try shaking mine and see if that works, since i might just get a new one, if we can't fix it
Pontuação 0
1 comentário:
i did not work :'(
por
My aunt’s DS lite’s power switch is broken. I would slide it to the on side but then it just moves to the off side. Is that supposed to happen?
Pontuação 0
Adicionar a sua resposta
khan786 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 80
Últimos 30 dias: 408
Ao todo: 94,163
