Ir para o conteúdo principal
O GameCube é o quarto console da Nintendo. O reparo é simples e exige apenas ferramentas comuns.
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
por
Glad that a new memory card did work! Have a great day :)!
por
Adicionar a sua resposta
Nirby 74 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 220
