Replacing screen on OnePlus Nord CE 5G
Hi all, a few weeks ago I dropped my OnePlus Nord CE 5G. It seemingly managed to hit the corner right between the screen protector and the actual case, which cracked a bit of the glass under the screen protector. This caused display issues and the phone wouldn't take any input, and by the end of the day the screen wouldn't display anything at all other than an occasional line or pixel. The phone was working perfectly before this and I know the phone was working other than the screen because my morning alarms still went off for another week before the battery finally drained. 😂 Unfortunately I couldn't get any data off it because I hadn't enabled USB file transfer, you have to activate a different setting to be able to use USB-C keyboards and it also doesn't support screen mirroring over USB-C.
I had a thought about if I could try replacing the screen to be able to access the files if I can find a cheap one. I'm wondering if there are any tutorials or guides for replacing the screen or at least connecting a new one. I had to get a replacement phone so I don't need it to be good enough to use as a daily phone, I just need to be able to type in my pin and enable the USB file transfer when the popup appears. Also, if anyone could advise on what kind of screen to buy as I'm not sure what the difference of it being "with frame" or not is. Thanks!
TLDR: Looking for a guide on replacing OnePlus Nord CE 5G screen and what kind of screen to buy.
Esta é uma boa pergunta?
