Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
Why is my left joystick rotating?
I was playing Jedi Survivor when all of a sudden something clicked on the controller. I have some light stick drift, which isn't an issue personally as I usually play singleplayer..
But the joystick is now rotatable? Usually when you use the joystick, it stays in the center and the stick itself doesn't rotate. Welp, this one does.
I'm not sure if this is replaceable or not, please assist!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The sticks has a cover over there, and the cover has the rubber part at the top, it can rotate because is only fitted there, so, humid places or contact with water (when cleaned your dualsense) makes the rubber part get more propitius to release, and to fix it must be replaced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 373
