Ir para o conteúdo principal
A furnace is a heating system that warms air or water through combustion of fuel or electricity, distributing heat throughout a building via ducts or pipes. Efficient and powerful, furnaces are central to home heating, offering quick temperature rise and consistent warmth.
Furnace keeps trying to start, but won't
My furnace is trying to start and blow heat but once it gets fired up it shuts back down. It does this constantly until you turn it off.
Esta é uma boa pergunta?
Pontuação 0
6 comentários:
Hi @nicholaswi67876
What is the make and model number of the furnace?
por
Also the energy source? If AC powered, its source as well.
por
@jayeff Guardian
GG9S100C16MP11A
por
So you have a York gas furnace (under a different name), is that correct? Are you using Natural Gas or Propane?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Hi @nicholaswi67876
If the furnace turns on and then shuts down shortly after it could be a problem with the flame sensor not detecting the temperature correctly.
Here's a video that shows how to replace it which may help.
As best as I can find out the part number shown in the video is the one for the sensor in your model furnace.
If you think that it may be the problem search online for 02537499000 to find suppliers that suit you best (examples only)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nicholas Wilbourn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 38
Ao todo: 202
