Ir para o conteúdo principal
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Perguntas Visualizar todos
Can I replace just the keyboard?
My MBPro A1286 Intel Core Duo Model 5,1 got wet last weekend. Now several keys don't work. I did some research and found out that most parts providers offer only replacing the top case along with the keyboard. (pretty expensive!) Then I found this site Link text that offers Just the keyboard (much better, money-wise) Seems to good to be true...Is this doable? and how come you don't have a guide here for this procedure? (did a search with my model number and the closest I got was to a top case replacement guide) Thank you!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
hi , yes its totally possible to change only the keyboard but its much difficult and take many time.
No guide on internet for replace only keyboard if i have time next week i will make a guide for you
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Yes, you can replace just the keyboard.
You can use this guide as an example:
Replacing keyboard on MacBook Pro 15" (Mid 2010)
The guide is for a different model but should be very similar.
Pontuação 2
Adicionar a sua resposta
gilarturo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 3,407
