Screen turns green/blue and unresponsive.
Versa 2 about 2 years old. Couple days before the screen would be unresponsive in certain areas— couldn’t turn off alarms in the bottom right corner but could swipe across the screen. After about 2 days of not fully functioning, the screen turned green/blue with the face fairly visible behind the blue. I could fairly see the clock in the background but the screen is mostly blue/green for a few moments before shutting off. This has happened 3 times. The first two times this happened I put the screen in rice for a few days and it resolved. I’ve since not worn the watch while in water but I do use it to work out. I’ve tried letting the battery completely drain, charging fully, ricing for a week— no improvement. Buttons are responsive, screen will turn on when charged but the screen is not interactive and still has a blue overlay. Is this a common error?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
