Ir para o conteúdo principal
Three second boot loop
Hi there, I have a 14" MacBook Pro (2021) that starts up when connected to charger, but then restarts after 3 seconds, and repeats the cycle indefinitely. When disconnecting the "battery board data cable" it starts up perfectly fine being connected to the charger only.
Is this a clear sign that the battery board/battery is faulty, or could it also be that there is an issue with the main/logic board? I don't want to replace the battery just to find out that there is something wrong with the logic board. That would be very sad.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Did you review this guide: MacBook Pro 14" 2021 Battery Replacement taking note of the BMU cable connections and the cable it’s self. I’m suspecting you need a new BMU cable as this one is likely damaged.
Battery management unit (BMU) flex cable P/N 923-06765
I would also install CoconutBatteryso you can see more clearly what’s happening.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Eric será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 141
