Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Microphone and Home Button don't work (1st Gen. iPhone)
My iPhone (1st Generation) was dropped yesterday. Everything is fine except the home button and microphone no longer work. Reseting the phone doesn't resolve the issue. The speaker does play sound, but the only way people hear me on calls is if I use a plugged in earpiece with a mic (or a bluetooth).
I don't see in your guides how to get to the wiring underneath the home button. Is there a loose connection I can check, or would I need to replace the whole unit? (same applies to the microphone)
Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Since the Dock Connector (USB port), home button, mic and speaker are in the same circuit, System Conector Flex maybe damaged. For your reference http://www.chinaontrade.com/apple-iPhone...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Wayne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Ao todo: 3,581
