Ir para o conteúdo principal
Unibody MacBook Pro models with 13" displays produced from 2009-2012.
Is it possible to dissassemble the LCD Panel?
I have a box full of maybe 15 or so old LCD's (A1278 2012) Models, some are with the vinegar effect, some broken connections etc.... Am wondering if I can rescue some of them by tearing them down and swapping over the good inner parts. Example being the vinegar effected ones with the likely clean backlight sheets from the cracked or broken ones. But they are sealed up quite well, has anyone attempted to do this before and if so how to open them up & securely put them together again?
Upon inspection it turns out that the 'vinegar syndrome' is an issue with the rear of the actual LCD glass and not with the reflective sheets and mold.... The rear of the LCD glass is visibly tainted with what looks like creases and scratches in the silver shinny backing, this was evident in 2 vinegar's that I checked.... drat.
Esta é uma boa pergunta?
Pontuação 1
8 comentários
The only salvageable parts if you have the ones with the backlight sheets and LED light bar are recovering them if they are still good. The LCD it’s self if it’s still good won’t be of much use without having good backlight sheets and LED light bar.
While not easy they can be opened.
por
@livfe how far are your LCDs already disassembled. Where are you i the process? You got the glass removed and are at the panel? Post some pictures of the sides as well as of he back of those panels.
por
@oldturkey03 The panels are taken out of the casing. In a box, still in one piece...... as like the picture above. I guess peel back the very sticky tape and they pop apart?
por
@livfe definitely a good start. Pull the tape and lets see what is hidden under it :-)
por
@oldturkey03 Have you ever done this before?
por
Exibir mais 3 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Yeah, it’s possible, but not easy. The biggest challenge is separating the layers (especially the polarizer and diffuser sheets) without creasing or contaminating them. If you want to swap backlight sheets from cracked screens to fix vinegar syndrome ones, it’s doable, but expect a delicate, tedious process. You’ll need a razor blade or plastic tool to carefully pry it open, and strong double-sided tape or a UV adhesive to reseal it.
Esta resposta foi útil?
Pontuação 2
1 comentário:
@pixelnero009 I have opened one up with the vinegar effect and inside looks spotless clean.... which sheet exactly would cause the effect? Do I simply swap over everything & hope for the best or anything specific? There is 1st the frame, then a white plastic sheet, then another sheet with a frame part on the top, then 4 or 5 other sheets.... The rear of the actual glass screen is not flat it has what appears to be waves or scratches on it, which I think would be the cause of the effect. So it seems that the vinegar effect is an issue with the LCD itself and not the sheets.... which isn't good news lol
por
Adicionar a sua resposta
livfe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 89
