Where can I download the drivers
where can i download the drivers
Acer Aspire One ZG5
display
ethernet
Esta é uma boa pergunta?
Acer Aspire One ZG5
display
ethernet
Right off Acer's website.... These links should work fine for you.
Display Driver - http://global-download.acer.com/GDFiles/...
LAN - http://global-download.acer.com/GDFiles/...
Wireless LAN (not sure if you meant this) - http://global-download.acer.com/GDFiles/...
Esta resposta foi útil?
do they work with wondows vista
Um... no... Acer seems to have only the XP versions... did you put Vista on this machine yourself?
yes I need the lan driver, vga display driver
Hi Liz,
I have a couple of Acer laptops; (different models just to make things a bit more interesting!) I have always managed to get the driver that I want from the link below.
www.acer.com.au/ac/en/AU/content/home
Hope this is of some use to you?
Cheers Al.
Hi, try this:
If you do not need Windows operating system, i install Xubuntu from: http://xubuntu.org/
burn it, boot xubuntu cd, choose "TRY Xubuntu" (loading operating system something like Windows Live), connect your internet, and choose install xubuntu now.
Install with all drivers, no need download drivers, all is automatic.
I recommended.
Thank you.
You need to go to acer official sites and then you need to click on this link http://www.acer.co.uk/ac/en/GB/content/g....
now you need to select your os type and then will get your drivers.
Else you need to download driver checker on your computer and then you need to run it. once you will run it then it will detect the drivers and download the drivers for you automatically.
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 56
Duração total: 36,634
5 comentários
http://www.acer.com.au/ac/en/AU/content/... Model name is AOA110
por Dimitrije
have the Acer Aspire model ZG5 and am having trouble with the speakers (sound) it sounds like it is cutting in and out
por ltr7
download acer driver here http://www.downloadwirelessdriver.com/se...
por onta nyasar
http://www.aiydriver.com/2016/03/acer-as...
http://www.aiydriver.com/2016/03/acer-ex...
http://www.aiydriver.com/2016/03/acer-tr...
http://www.aiydriver.com/2016/02/acer-as...
http://www.aiydriver.com/2016/02/acer-47...
http://www.aiydriver.com/2016/02/acer-tr...
por aiy ub
acer drivers http://driverrestore.com/download-update...
por lissacoffey
